CPM Grid Last Row Styling Issue
My client recently upgraded to CPM 7.1.3 on Pega 7.1.8. After the upgrade they are seeing an issue with the borders of the last row in the grid.
See screenshot attached. The grid is OOTB with Style set to "Default" and Container Format set to "None".
The css that is causing this to happen is in the rule cpm-override css in PegaAppCA:07-13-02
See screenshot below:
Before I go and override this, wanted to check if there is something else I need to do. This is happening to all the grids in the application and so creating a custom format and setting the css is out of the option.
Thanks.
