CPDC v8.4 Practice Exam
Apart from the final module quiz, where do I find practice exam's for CPDC v8.4? Any help is appreciated. Thanks!
Thank you Miki for taking time to respond! Appreciate your support. Thanks!
Sep 16 2020 update @ Miki & @ Chastity thanks for all your inputs. Was able to clear PCDC 84V1 exam today.
Hi there
Unfortunately, there are no additional practice exams for this course.
Chastity
Thank you Chastity!
Will there be a huge difference in question patterns for Ver 8 & Ver 8.4. Just wondering how to prep for the 8.4 exam in the absence of any additional practice exams. Appreciate your support & time. Thanks!
Chastity is right that we do not have an explicit course/module/mission for the practice exam, however in the new PA 2020 the equivalent of the practice exam is the mission test. This you can find at the end of the mission.
You can see some additional info also here: https://collaborate.pega.com/question/cpdc-v8-practice-exam
Regarding the exam questions, these are more scenario based, similar to what you will see in the mission tests.
Good luck with the exam!
Miki
Congratulations!!!
Marissa | Senior Moderator | Pega Collaboration Center
Hi
Seem there is no link to access practice exams for
Pega CPDC & PCDS .Refer to codes C-1400 and C-1821 respectively
Can you help please!
Edward
