brunomendes
brunomendes
BR
brunomendes
Posted: Nov 20, 2025
Last activity: Nov 27, 2025
Last activity: 27 Nov 2025 18:14 EST
Constellation´s Table Cells Shift focus with arrow keys
I´m using Constellation 24 and would like a feature to enable navigating through tables CELLs in the UI using the Arrow Key.
Read Only tables works fine.
We need the feature to work with Editable Table Lines.
Column with the Description are read-only, all others are Decimal Editable. When we use the arrows it increments the value within (by desing I presume) instead of the UI need to move around to other CELLs.
