Paul Hartmann AG
DE
Last activity: 24 Mar 2021 15:07 EDT
CONNECT-REST:A remote host did not respond within the timeout period. (Connection timed out)
We are facing one issue. When Connect Rest is called directly , it is working fine but when called from sla activity it is giving connection timeout error. In Development environment, it is giving alert but in Testing environment it is giving error, Does anyone know about this? Any Solution?
We tried updating this settings but after around 6 seconds it is giving the same error,
Pega-Engine • prconfig/timeout/application/default
Pega-Engine • prconfig/timeout/browser/default
Error:
[HTTP connect execution failure: org.apache.http.conn.HttpHostConnectException: Connect to ********] failed: A remote host did not respond within the timeout period. (Connection timed out)][STACK][java.lang.RuntimeException: org.apache.http.conn.HttpHostConnectException: Connect to ***********] failed: A remote host did not respond within the timeout period. (Connection timed out) at com.pega.pegarules.integration.engine.internal.client.rest.ComponentsRESTClient.invokeRESTClien
