Manheim
Last activity: 16 May 2016 13:13 EDT
Column generated through optimization wizard not having a value after commit
The optimization wizard was executed on a property called
- InventoryItem.ReleaseDate( pyWorkPage belongs to classgroup called CAG-FW-ICFW-Work). This created a new column called releasedate_1 in the database table(work table) and also added the external mapping in the class rule(CAG-FW-ICFW-Work) with the column name mapped to this property.
However, when work items are commited into the work table, some of these records aren’t populating this new column releasedate_1 with the value from the property. The expectation is that Pega should populate this new column with the value from the above property always.. However some records in the table doesn’t have a value for this column eventhough the property in the clipboard has the value.
Interestingly, this never happens in our dev environment and in QA some records have a value in the column and some doesn’t have a value(inconsistent) eventhough the property in the clipboard has this value.
Can you please throw some light on this issue?
Hi Sankar,
Have you compared Log and Tracer from both working and non working environment ?
This should be the first step to identify why it is not working in a particular environment ?
Also , check whether the users are having proper privilege to write data on DB.
Manheim
There is no priviilege issue as the commit is successful and only this column has a blank value.. Had this been a privilege issue, records won't get committed into the work table.
Also the log trace and trace from both the environments are alike.
Sethu
Can you check where there are more than one properties of the same name present in the class hierarchy with perhaps different case?
Manheim
Vipin,
Yes.. Actually there are 2 properties
pyWorkPage.InventoryItem.ReleaseDate ( InventoryItem page property is in the work class cag-fw-icfw-work and this inventoryitem page property has a property called ReleaseDate.. This property was optimized using the optimization wizard in pega)
There is another property called ReleaseDate with the same case and type, however this is directly under the work class(CAG-FW-ICFW-Work). This is however not used for optimization.
These 2 properties exists in both the environments(Cox5 and Cox6) and the optimization wizard was run against InventoryItem.ReleaseDate in both the enviroinments. This created a new column called ReleaseDate_1 in the work table and the wizard also added an external mapping for releasedate_1 to inventoryitem.ReleaseDate in the cag-fw-icfw-work class in both the environments.
The column releasedate_1 is consistently getting populated in dev, however in QA some records have a value for this column and some doesn't have a value for this column(inconsistent).
Sethu
I believe this is a known problem. Suggest you to enter an SR and someone in GCS can help validate if this is working as designed.
At the very least we need to inform the user about the duplicate properties rather than having this inconsistent issue. You may also try removing the property that is not desired and try running the optimization tool.
Manheim
Vipin,
Thanks for the update. I have already logged a support request to track this problem.
Sethu
Hi Sethu,
Could you please reply with the SR number you created with GCS?
Thanks!
Manheim
SR-A21599 is the SR#
Thank you!
JP Morgan
Please save the Data base table instance for that particular class once ...If this is also not working try to save the class as well
Hi Sethu Sankar,
While reviewing the SR associated with this thread, I see that the SR has been withdrawn due to the fact that the issue stopped occurring.
I will be closing this thread. If it happens again, please re-open this thread and leave a comment.
Thank you!
