cluster identifier
We are migrating from 6.3 to 7.2.1. The approach is that the rules schema will be copied from the lower environment into the higher environment and then a dataOnly upgrade done on the data schema.
When I look at the DSS for 7.2.1, I see a setting that we don't have in 6.3. When we copy the rules schema from the lower environment to the higher environment, will the cluster name/value be updated by PRPC or, do I need to update it? If so, where do I find the cluster identifier?
Pega-Engine
prconfig/identification/cluster/name
567dab9f406778ce85484da5dbd0d568
