CLSA71- Rule Reporting Exercise - Cannot show properties from joined history-rule class
When i add the pyPerformer property from the joined History-Rule class in a report on the Rule-Summary class as described in the Rule reporting chapter,the property seems not to get recognized.
In the query form the column name field gets cleared when saving and the following error messages show:
Property Label:A Column Heading is blank: 'RH.pyPerformer'. Enter a heading for this column.
Property Name: This is not a valid property or this is a property that cannot be used here.
See also the attached screenshots.
Did anyone else face the same issue? Am i overlooking something?
Thanks in advance,
Niels
PVS Pega version 7.1.9
