Sun Life Financial
Last activity: 21 Dec 2022 12:40 EST
Can we select the records in a table(pagelist results) based on column filters in multiples of 10
Hi ,
In a table layout we are displaying the Pagelist results. Here the first column header is a drop down with values (10,20,30,40) and its respective column are of check boxes. And the remaining columns are text labels and data.
Here the requirement is , if we apply column filter on Province and country in the table, and if try to select a value from drop down of first column header(lets say 20), then can we select first 20 records based on considering the column filter also(meaning the first 20 records after column filter needs to be selected) instead of initial Pagelist pxresults.
| Drop down (values 10,20,30,40) | Province | Country |
| Check Box | Atlanta | USA |
| Check box | Ontario | Canada |
| Check box | New York | USA |
