Can we integrate with PingOne Advanced Identity Cloud (formerly known as Forgerock)
Do we have any documentation or regarding the PingOne Advanced Identity Cloud platform?
@MUELM Yes, you can integrate with PingOne Advanced Identity Cloud (formerly called ForgeRock Identity Cloud). It supports features like Single Sign-On (SSO), identity governance, and REST APIs for user and access management. PingOne provides step-by-step guides and documentation to help set up authentication flows, connect external apps using OAuth or SAML, and manage users using SCIM. You can also integrate with other services like PingOne Protect for risk-based authentication. The official documentation is available at docs.pingidentity.com, and API references are at apidocs.id.forgerock.io. If you’re using on-prem web agents, they can also be configured to work with the cloud. Integration examples and training are also available through Ping's community and support portals.
@Sairohith - thank you very much for your feedback and guidance. I am curious, do you need to create a specific authentication activity, or will the standard open auth activity that is in the templated Auth service work ootb?
Support Doc
