Can we create field value for Skill Name?
I have a report (created in Data-Admin-Operator-ID) that uses pxSkillName (Index-OperatorSkills) as a column. For example, if Skill Name is "Helloworld", I want it to appear as "Hello World" on UI (Section: Data-Portal). I tried creating a field value for pxSkillName, but it is not reflecting. Also, in the index table, there is no column that has Skill's Label.
If any of you have come across something like this, please suggest a solution.. Thanks
