Can Pega 8.x platform be deployed on AWS ECS and AWS Fargate containers?
Would like to know if Pega 8.x can be deployed on containers using below options
1) AWS ECS
2) AWS Fargate
1) AWS ECS
2) AWS Fargate
We do not support either OOTB. Given the industry wide acceptance of kubernetes (k8s) as the standard container orchestration platform, most of our current work is based on EKS (or AKS for Azure), etc. You should take that into consideration if you are still early in your planning stage. Check the Pega cloud choice link and watch for new upcoming exciting news regarding K8S support from Pega: https://www.pega.com/products/cloud/customer-managed-cloud
Since this response is about an year old, with latest updates, are these combinations supported ?
1. PEGA Infinity on EKS with AWS FarGate
2. PEGA Infinity on ECS with AWS FarGate
In the documentation https://www.pega.com/products/cloud/customer-managed-cloud, it's clearly stated that AWS EKS is supported but it does not call out anything on leveraging Fargate.
@trina_r We have found the relevant information on what's supported in the context of a Customer Managed Cloud -
EKS on AWS Fargate is not supported yet (as of Jan 2021)
ECS is not supported yet (as of Jan2021)
The following web resources describe the Pega approach to Client Managed Clouds. Note: the current released version of Pega is 8.5
https://community.pega.com/knowledgebase/articles/client-managed-cloud/85/about-client-managed-cloud
https://github.com/pegasystems/pega-helm-charts#pega-deployment-on-kubernetes
https://github.com/pegasystems/pega-helm-charts/tree/master/docs
The following Kubernetes environments are supported. Pega provides configuration templates so you can customize your deployment into one of these supported Kubernetes environments, in addition to other settings your organization needs to deploy Pega Platform™ for your business needs.
Kubernetes Kubernetes 1.15 and later
OpenShift Red Hat OpenShift 3.11 and later
Amazon EKS Kubernetes All supported EKS versions.
Google Kubernetes Engine (GKE) All supported GKE versions.
VMware Enterprise Pivotal Container Service (PKS) Pivotal Container Service 1.4 and later
Azure Kubernetes Service (AKS) All supported AKS versions.
