can anyone help me with the Activity for "Html to WordDocument"
Need an activity for Word document generation, can anyone help me with the Activity for "Html to WordDocument"
Create a New Activity:
ConvertHTMLToWord.Add Steps to the Activity:
Step 1: Use the Property-Set method to set the HTML content you want to convert. You can store this in a property, e.g., HTMLContent.
Step 2: Use a Java step to convert the HTML content to a Word document. You can use libraries like Apache POI or Docx4J for this purpose. Here’s a sample Java code snippet:
import org.docx4j.openpackaging.packages.WordprocessingMLPackage;
import org.docx4j.convert.in.xhtml.XHTMLImporterImpl;
String htmlContent = myStepPage.getString("HTMLContent");
WordprocessingMLPackage wordMLPackage = WordprocessingMLPackage.createPackage();
XHTMLImporterImpl xhtmlImporter = new XHTMLImporterImpl(wordMLPackage);
wordMLPackage.getMainDocumentPart().getContent().addAll(xhtmlImporter.convert(htmlContent, null));
ByteArrayOutputStream baos = new ByteArrayOutputStream();
wordMLPackage.save(baos);
byte[] wordBytes = baos.toByteArray();
myStepPage.putString("WordDocument", Base64.encodeBase64String(wordBytes));
Step 3: Use the Property-Set method to set the generated Word document content to a property, e.g., WordDocument.
Save and Test the Activity:
Create a Data Transform or Flow Action:
Generate the Word Document:
@RaghavN2 First you need to kake sure the HTML content is well-formed and stored in a parameter like Param.HtmlContent. Use a Java step in the activity to handle the conversion. You can leverage the Apache POI library, which is commonly used for working with Word documents. In the Java step, initialize an XWPFDocument object, create a paragraph using XWPFParagraph, and add the HTML content as text using XWPFRun. Save the generated document to a specified file path, like /GeneratedDocument.docx, using a FileOutputStream. Handle errors gracefully by checking if the HTML content is empty or if any file writing issues occur. Once the document is created, store the file path in a parameter (e.g., Param.GeneratedFilePath) for further use. Test the activity with different HTML inputs to ensure the generated Word document meets your requirements
