Calculating the cost of a flow
What is business use case for calculating cost of a flow
Can you clarify, what do you mean by "cost of a flow" ? Time spent on the flow ?
Please refer the link below
As it is mentioned in the above link, you can assign a cost to a flow by defining values for assignments and flow actions that are added together at run time. By collecting information about the path that a flow takes, you can generate metrics that are specific to your application.
The link provided an example: you can assign different monetary amounts to assignments in a service repair flow to calculate the total price of parts to order.
Your application can use these numbers to identify the source of charges or for other accounting purposes.
