Bus Architect Essentials 8 login via VMWare
the login details provided in the course material do not allow me to login in. please advise.
What login credentials are you using? Are you certain you are using the correct VMWare image?
If you could provide screen shots and steps that would allow me to reproduce your issue it would be great as I am able to login without issue.
Sean
Pega Academy Self-Study Support Team
Hi Sean,
I just followed the installation instructions provided on the BA 8 course. I installed VM Ware. In a dos like window, I am required to provide login details. And I tried author_DM@gogoroad and rules, and other combinations I found on the forum. Anything I tried got me “login failed”. I cannot provide with screen shots.
Hi Sean,
How can I tell I am using the right vmware image? It is the one I downloaded from the course.
Can you tell me what user name and password I need to use for the VMWare?
When using the cloud environment, I used the above credentials and it worked.
Some of the screenshot provided in the BA 8 course (if not all) are from Pega 7, even instructions. And within the VMWare, the message is to open Pega 7 … could this be the issue?
Thank you
Beatrice
The v8 PCSSA VMware course is very straight forward. When the windows command window opens just leave it be. Open your browser and to the indicated url Http://192.168....
When the browser opens login should be Proprietary information hidden password = rules
John is correct, don't use the dos based virtual machine window. Instead open up your browser of choice, I use Chrome and enter the IP address you are seeing in that window. Please make sure to give it about 4 minutes the first time you start your virtual machine to start all the services.
Once you have a login screen in the browser you will use the login author_dm@gogoroad and a password of rules. John was referring to another course and not the BA course.
Please let me know if this resolves your issue,
Sean
