Virtusa
Last activity: 26 Aug 2020 13:16 EDT
Built on component properties are not listed for drag and drop in pega express
#helpme
While doing Exercises given in LSA Architecture Course 7.3,7.4 in DESIGNING FOR SPECIALIZATION chapter Exercise:Constructing the email application
Send Email property is not displayed in properties list for pega express configure view window, below are the steps given in Excercise
#helpme
Create the email case type and case life cycle
- At the bottom of the Explorer panel, click Switch to Pega Express mode and add an Email case type.
- On the Case Designer Workflow tab, add an Email case type life cycle that includes the following stages:
- Enter Test Data
- Prepare Email
- Edit, Send, or Skip
- Resolve Email
- On the General tab in the Stage panel, set the first three stages to Automatically move to next stage. Set the Resolve Email stage to Resolve the case.
- In the Enter Test Data stage, add a Collect Information step named Enter Test Data.
- On the General tab in the Step panel, select the Configure view button to open the views dialog. Do the following on the Fields tab:
- Expand the Fields section on the left
- Drag and drop the When To Send Email property beneath the Add field link. This property is part of the Email Editor component and is used to set a future date and time.
- In the Options field, select Required.
- Click Submit to save your updates.
