Building reports based on sum of 2 case types and properties associated to the 2 different case types
Hello All,
I currently have a requirement to build reports in (using pega version 8.3.) I was wondering if its possible to build a report that pulls the amount of total cases that are tied to a certain property that are used in two different case types as well as the total sum of both case type in one report.
There are two different case types which I need to report on, is it possible to do this in one report? For more context an example would be to create a list/ summary report that lists total/sum of cases of case type x as well as type y.
The last requirement is to report the use of a specific property that is used in both case types and list total/all cases (case type x plus case type y), total pages of case type x, total cases of case type y, and total case type of case type x
For example a insurance policy holder (PolicyHolderName) is a property that is used in case type PNG-TrustyInsurance-Work-Quote, as well as PNG-TrustyInsurance-Work-Review I would need a report that lists:
PolicyHolderName
- Total cases
-Total Quote cases
-Total Review cases
-Total Pages of case Quote
-Total Pages of case review
and so on an so forth based on all PolicyHolderName
Hello All,
PolicyHolderName
- Total cases
-Total Quote cases
-Total Review cases
Many thanks in advance on any input or guidance on how to implement this requirement (or if it is possible) So far i have been experimenting with creating a custom report definition however given the fact that two case types are involved I wanted to know if there is a more efficient way to implement these requirements. Once again thank you very much for the support (:
***Edited by Moderator Marissa to update Content Type from Discussion to Question***
