Scotiabank
Last activity: 8 Dec 2022 16:50 EST
BIX Extract rule configuration to define Not Null (Mandatory) and also populate elements with empty tags
Hi Team,
As part of reporting requirement, we have defined BIX Extract rule with output format as XML.
Based on the PEGA feasibility we are able to define the list of properties that need to be extracted but not the able to specify the NOT NULL option. By default, all the elements in XSD are described as minimum occurrence as 0 i.e., all properties are kind of optional and the Consuming team is specifically asking us to validate the below requirement is feasible in PEGA or not?
1. Is it Possible to define Not Nullable properties in the extract so that XSD will be generated with required fields with definition.
2. By default, Pega will not populate the elements in the output xml file if the value of the property is empty/null. Is it possible to make any config change at pega so that we can generate empty tags with any of the following format i.e., <ElementName></Element> or <ElementName>NULL</Element>
