BIX Extract is failing when configured from an agent
We have configured the BIX rule from agent but we are seeing exceptions when the agent runs. Below is the exception we are getting.
2016-12-20 19:47:00,354 [ PegaRULES-Batch-1] [ ] [ Complaint:01.01.02] ( internal.access.ExtractImpl) INFO - BIX Version : 7.1
2016-12-20 19:47:00,511 [ PegaRULES-Batch-1] [ ] [ Complaint:01.01.02] ( internal.access.ExtractImpl) INFO - Target database using batch inserts
2016-12-20 19:47:11,723 [ PegaRULES-Batch-1] [ ] [ Complaint:01.01.02] ( internal.access.ExtractImpl) ERROR - Batch Update Exception: [jcc][t4][102][10040][4.18.60] Batch failure. The batch was submitted, but at least one exception occurred on an individual member of the batch.
Use getNextException() to retrieve the exceptions for specific batched elements. ERRORCODE=-4229, SQLSTATE=null
com.ibm.db2.jcc.am.BatchUpdateException: [jcc][t4][102][10040][4.18.60] Batch failure. The batch was submitted, but at least one exception occurred on an individual member of the batch.
at com.ibm.db2.jcc.am.kd.a(kd.java:475)
at com.ibm.db2.jcc.am.Agent.endBatchedReadChain(Agent.java:414)
at com.ibm.db2.jcc.am.cp.a(cp.java:5238)
at com.ibm.db2.jcc.am.cp.c(cp.java:4825)
at com.ibm.db2.jcc.am.cp.executeBatch(cp.java:3036)
at com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl.executeBatch(DatabasePreparedStatementImpl.java:534)
at com.pega.pegarules.data.internal.access.ExtractImpl.insertRowsBatchMode(ExtractImpl.java:5811)
at com.pega.pegarules.data.internal.access.ExtractImpl.doExtract(ExtractImpl.java:3347)
at com.pega.pegarules.data.internal.access.ExtractImpl.runExtract(ExtractImpl.java:1730)
at com.pega.pegarules.data.internal.access.ExtractImpl.init(ExtractImpl.java:1383)
at com.pega.pegarules.data.internal.access.ExtractImpl.parseAndRunExtractCommand(ExtractImpl.java:1328)
at com.pega.pegarules.data.internal.access.ExtractImpl.executeCommandLineExtract(ExtractImpl.java:1045)
at com.pega.pegarules.data.internal.PRDataProviderImpl.executeCommandLineExtract(PRDataProviderImpl.java:1314)
at com.pega.pegarules.session.internal.mgmt.Executable.executeCommandLineExtract(Executable.java:8282)
at com.pegarules.generated.activity.ra_action_pxextractdatawithargs_af9552bf7ad754cbdac2e3d257607afb.step3_circum0(ra_action_pxextractdatawithargs_af9552bf7ad754cbdac2e3d257607afb.java:411)
at com.pegarules.generated.activity.ra_action_pxextractdatawithargs_af9552bf7ad754cbdac2e3d257607afb.perform(ra_action_pxextractdatawithargs_af9552bf7ad754cbdac2e3d257607afb.java:103)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3500)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.runActivity(QueueProcessor.java:721)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:602)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:945)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1259)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:901)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:670)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532)
at java.lang.Thread.run(Thread.java:745)
Environment details: Pega 7.1.8
BIX: 7.1
DB: IBM DB2
We created below DSS but no luck.
Owning Ruleset: Pega-Engine
Setting Purpose: prconfig/database/batchUpdates/default
Value: -1
Any help would be appreciated.
Bharatesh
