Barclays
Last activity: 28 Sep 2019 17:08 EDT
Autocomplete Vertical Scroll Bar missing in Production (IE Only)
Hi Guys,
**Happening in PROD Only**
seeing weird issue with Autocomplete control where it has more than 100 records to display. When accessing the application from Chrome, its working fine and I am able to vertically scroll through the results, but when accessing from IE, dont event see any vertical scroll bar.
It is an expected behaviour of Autocomplete in IE.
List based ACs are designed to perform better and load results quickly, but they will show the top 8 results. If user want to filter more results, he has to type more characters. This is the intended use of ACs.
Moreover, in a table based AC, if you are loading more than 100 results it will definitley perform slow. same behaviour can be observed in grids if it loads more than 100 results without pagination. This is not supposed to be an intended use case of Autocomplete as per design.
It is suggestable to show lesser results or change it to list based AC.
You can check below support article which is similar to your issue. It may help you.
You can try to give 'Max results displayed' in the Autocomplete control a smaller number, eg. 10.
Please use developer's tools to figure out the difference in the CSS code in both the browsers.
Wipro
- Are you using a table view or list view?
- If list, have you checked "Allow scrolling for more results"?
- Does this happen with lists smaller than 100 records?
- What is the behavior in UI gallery?
Adding to my colleague's comment you can restrict the user to enter more number of characters to show the list (for example "Min Search Character" value can be set to 3 or 4 so that the matching list will be shown after entering atleast 3 or 4 characters). This will allow the list to be small.
Barclays
Thank you all for your inputs. I gone through the autocomplete design and seems it was pulling all the results without any "Max results displayed" and "Min search characters" restriction. I think I need to talk to the BAs and revert back to the user about the control's OOTB behavior.
Hi @Abhinav_Chaudhary - Can you confirm your application behavior with the OOTB autocomplete control on the UIElements. If the control is not honoring Max results and Min search options, then that is a legit problem. But, pl confirm the behavior on OOTB controls and submit an SR if you confirm there is a bug here. We can assist you further! Thank you.
