Auto property substring based on the expected length
Is there a OOTB function that the property will automatic truncate the last characters based on the expected length without using datatransform and substring?
Example : property FirstName, database size 5 and we want only length 4 only be stored in DB. If the value we set is Joseph, the value we will store is Jose. It is like a configuration in the property level instead of looking for all the reference rule to update and add substring.
Thank you in advance for your kind assistance.
Ramon
Hi Ramon,
You could try to use the function truncateLongText.
ex: @(Pega-RULES:String).truncateLongText(<string>, <max length>)
Hope it helps!
Gisela
