Wells Fargo
Last activity: 30 Apr 2018 4:15 EDT
Authorization Levels in Pega
Hi Guys,
I have a question around Access Control/Authorization in Pega.
Suppose I want to hide certain functionality in the application from a set of users. I can simply hide the link to that particular module/ functionality say a grid or tab or menu item using a condition such as pyAccessGroup should be XYZ (Visible When or Enable When).
Then why do we need to define authorization/security at even granular levels such as access roles and privileges.
Is this a way to make the security model more robust and at the class level also (assuming access roles incorporate various classes and associated privileges)?
If I only deny access based on the example I gave, i.e. hiding a grid or menu item from user based on a simple condition such as .pyAccessGroup=="Appl:Admin", can this security pose threats and is compromising in real time?
Please explain in detail.
Thanks!
Bhagyashree
