Authentication of stream data sets
We created a stream data set with basic authentication and using the data set from a real-time data flow work item. Also, created a new operator with new access group & role, that has no Access Role to Object defined for testing purpose only.
The new access group is used in the work item access group & new operator is used in the REST service call.
The stream data set gets the request and DF run completes successfully even they should not have any access at all..
2 questions that we need to clarify on that:
- What is the authentication schema for the created stream data in general?
- How does the above scenario work even it should have no access?
I would be really appreciate if you could help..
Ezgi
***Edited by Moderator Kayla to update Platform Capability tags****
