Authentication and Authorisation with Pega Mashup
Hi team,
I am new with Pega mashup and trying to understand the architecture design to integrate with the currently existing site which is designed in Angular 2 platform.
I have gone though couple of links, but doesn't make things very clear. Would you be able to provide
information on how should I begin with on the following requirements :
1) Authentication and authorisation of the users. Now, the current application does not support SSO, so what should be the other solution to support Authorisation and authentication.
2) in which format the data is received from Pega, which can be further parsed to embed in application.
Could you please provide step by step procedure to achieve this task.
Deeksha
