Stella
Last activity: 1 Dec 2021 12:36 EST
Assignments and work groups
When transferring a case to an operator the assignment that gets created seems to set its pxWorkGroup as the primary work group of the operator it is being assigned to. If an operator is a member of more than one work group how can this assignment be created under one of the other work groups that the operator is a member of? It would seem to me that the only way would be to modify the operator to switch the primary work group before transferring the assignment. The operator transferring the case wouldn't know to inform the other operator to switch his or her work group. This would not be a good solution.
@TerranceK4053
Pega will have their code in a specific standard/business format. But in all pega ootb api activity which we are using maximum pega will have some extension point. By using this extension point we could be able to achieve custom business needed solution.
For your scenario if you are using pxTransferAssignment api activity for reassigning case to an operator/work basket then you could make use of pyTransferAssignmentDefaults api extension activity, in which you could have your logic to calculate work group and you could be able to override the pega ootb calculated values.
You would need to find the extension points which pega provided in all scenario's for building any business related solution on top of pega ootb code.
