Accenture Solutions Pvt Ltc
Posted: Jun 30, 2025
Last activity: Jul 9, 2025
Last activity: 9 Jul 2025 21:32 EDT
any latest Pega training which is essential to be taken by a Pega functional tester?
@AparnaP16614286 As a Pega functional tester, the latest and most useful training is the Pega Test Management Framework (TMF), which helps you create and manage test cases easily. You should also take the “Testing Applications” course available on Pega Academy to understand how to test case types, data, and user actions using tools like Tracer and Clipboard. It’s good to learn a bit about Selenium or SOAPUI if you plan to do automation or API testing. Though optional, learning the basics from the Certified System Architect (CSA) course can help you understand how the Pega application works. These trainings will improve your testing skills and help you test Pega applications more efficiently.
