Capgemini
Capgemini
IT
Capgemini
Posted: Jul 23, 2025
Last activity: Aug 17, 2025
Last activity: 17 Aug 2025 23:26 EDT
Additional resources for migrating from Pega 8.8 to Pega 24.2
We are upgrading from Pega 8.8 to Pega 24.2. Pega is already in a on-premise containerized infrastructure that will not change (apart form a version upgrade).
Also, we won't add any new component (i.e. Constellation, Cassandra, etc.).
Do we need to consider planning any resource increase either on the Pega side or DB side, considering that there will not be any change from an application perspective?
@AlessandroPic1
usually no big increase is needed if you’re not adding Constellation, Cassandra, or new features, but plan a buffer. Here’s the thing: move your containers to Pega 24.2-supported JDK (17) and base image, and keep the same CPU/memory to start; raise JVM heap by ~10–20% only if GC pauses grow under your normal load. Make sure Search (SRS) nodes can handle a full reindex after upgrade; give them short-term extra CPU and I/O during reindex only, then scale back. Queue processors and batch jobs changed a lot since 8.8, so watch their throughput and raise worker threads or node CPU before adding RAM. On the DB, you generally keep the same vCPU/RAM, but you need extra temporary disk/IO for schema upgrade, reindex, and statistics refresh; plan a maintenance window with 20–30% IOPS headroom. After go-live, compare AWR/pg_stat/latency against your 8.8 baseline and tune caches (rule/data) rather than throwing hardware. If you use BIX/DFs, test peak runs—these are the first to expose resource gaps. Final tip: load test your top 5 journeys at 1.2–1.5× expected traffic on 24.2 and only then right-size.
