Capgemini
Last activity: 5 Oct 2021 2:51 EDT
Adding legacy webchat conversational process in a casetype copies invalid properties on pyWorkPage
Legacy webchat conversational parallel processes have been added in the stages in casetype rule. The case is created through the chatbot and it works properly as configured. However, it is observed that a few OOTB properties(names below) are set in the work page but the applied to class of those properties are different than the workclass. Open assignments on the case can be submitted in pega portal without any issues but we are getting validation errors when the same assignment is completed though DX api e.g. from custom React frontend.
It seems to be a product issue. Any known workaround/fix available ?
OOTB properties with different applied to class that are set on pyWorkPage with values -
pyQuestionDropDownType
QuestionMode
pyConversationConfiguration
pxQuestionDataPagePrompt
pxQuestionDataPagePromptValue
pyConversationQuestionFormat
pxQuestionDataPage
pyIsConversationShape
These properties are set in embedded pagegroup property pyQuestion in pyWorkPage with appropriate class context.
It seems these are somehow getting copied into pyWorkPage in step 4 of OOTB activity pxSupplyAnswerToQuestion
Error returned in response to DX API -
QuestionMode
pxQuestionDataPage
Response Body : {"pxObjClass":"Pega-API-CaseManagement-Assignment" ,"errors":[ { "ID":"Pega_API_055" ,"message":"Validation messages found." ,"pxObjClass":"Pega-API-Error" ,"ValidationMessages":[ { "pxObjClass":"Pega-API-Error-ValidationMessage" ,"ValidationMessage":"The page contains an undefined property: pyWorkPage.pyQuestionDropDownType\nThe page contains an undefined property: pyWorkPage.QuestionMode\nThe page contains an undefined property: pyWorkPage.pyConversationConfiguration\nThe page contains an undefined property: pyWorkPage.pxQuestionDataPagePrompt\nThe page contains an undefined property: pyWorkPage.pxQuestionDataPagePromptValue\nThe page contains an undefined property: pyWorkPage.pyConversationQuestionFormat\nThe page contains an undefined property: pyWorkPage.pxQuestionDataPage\nThe page contains an undefined property: pyWorkPage.pyIsConversationShape\nValidation failed: Errors Detected." } ] } ] }
Pega build - PRPC-8.6.0-101
Thanks.
