Cognizant
CH
Last activity: 1 Apr 2020 9:34 EDT
Add a new locale to the system - en_CH
I'm working for a Swiss client on an English language application.
The requirement is that date format, currency format, etc. be according to the Swiss standard (like de_CH), but the language of the user interface be English (not German).
After some search it looks like using the "en_CH" locale would be the good solution (see: http://www.localeplanet.com/icu/en-CH/index.html), but it's not available in the system (see checks below).
I guess custom Java coding it should be possible, but as it looks like Pega has multiple customization around localization, I would prefer a Pega-approved (OOTB) solution.
Is there a possibility to add a new locale to Pega (8.1.5), if so, how to do it?
Any ideas, solutions, case studies are much appreciated.
Best regards,
Attila
Checking the available locales with a Java step ("en_CH" is not in the list):
java.util.Locale locales[] = java.util.Locale.getAvailableLocales();
for (java.util.Locale locale : locales) {
content += locale.toString() + "<br />";
}As the PRDateFormat class's JavaDoc says Pega uses the ICU library, I also checked the installed ICU data in Pega's database:
Best regards,
Attila
select distinct pzjar, pzpackage, pzclass
from pegarules.pr_engineclasses
where lower(pzpackage) like 'com/pega/ibm/icu/data'
and lower(pzclass) like '%ch%'
PZJAR: pricu2jdk.jar
PZPACKAGE: com/pega/ibm/icu/data
PZCLASS: it_CH.res, it_CH.xml, fr_CH.res, fr_CH.xml, de_CH.res, de_CH.xml
