Accessing Interaction.GlobalDictionary Variables/Properties by Dynamic Name
We're looking for a means of accessing the GlobalDictionary variables/properties by name, as if it were a standard collection.
IE: globalDict.Collection.Item['PropertyName'] = NewValue;
Any ideas on how to build out an automation or script without using a hard-coded switch statement to maintain the text->object relationship that allows accessing the GlobalDict variables by string name? We need to set the values of the dictionary, but we have the var names as strings, not objects.
-Chris
Can you instead use a LookupTable setup as a key/value pair? That is what I have always done in this use case. Basically, you setup the LookupTable with two columns. You can call AddRecord to add a row into it and GetRecord to get the data out.
