Tokio Marine & Nichido Fire Insurance Co.,Ltd.
JP
Last activity: 19 Apr 2024 12:26 EDT
About defects in Pega Robotic Desktop Automation
We are implementing an app that automates screen operations on Salesforce using Pega RPA, but due to the version upgrade of Salesforce (Spring24), an issue has occurred where it does not operate correctly.
Therefore, could you investigate and provide guidance on countermeasures based on the following information?
※Versions used
Pega Robot Runtime v Proprietary information hidden
Pega Browser Extension 3.1.7
Background
・An app that operates screens on Salesforce was built using Pega RPA.
・It was operating normally until before the version upgrade of Salesforce (Spring24).
・It operates on the Edge browser, using the Pega extension turned on.
※Versions used
Background
Issue
After the version upgrade to Salesforce (Spring24), the operation of Pega stops at the Salesforce login screen. Even manual login results in an error under these circumstances. Therefore, when the Pega extension on the Edge browser is turned off, manual login is possible. However, with the Pega extension turned off, Pega does not operate.
What has been checked
・When the extension is turned on, “Pega.Web.MessagingHost.exe” starts, but forcibly terminating “Pega.Web.MessagingHost.exe” while the extension is ON does not change the situation, and a login error occurs.
・Even after selecting “Specific sites” for the extension's “Site access” and registering the following sites, the issue persists, and a login error occurs.
https://tmn-anshin-cc.lightning.force.com/*
https://tmn-anshin-cc.my.salesforce.com/*
Confirmed with Salesforce
Upon checking the HAR file on the browser, it was discovered that there are differences in behavior between successful login and failed login. Details are in the attached file.
Request for confirmation
Since there are differences in Salesforce's behavior with the Pega extension turned on and off, after reviewing the details in the attached file, we would like to receive guidance on any countermeasures that would allow normal operation even with the Pega extension turned on.
***Edited by Moderator Marije to add Support Case INC-B12828 **
