Evonsys (PVT) LTD
LK
Last activity: 20 Nov 2025 22:32 EST
How to split a comma-separated string and add the values into a Value List property?
I have a string that contains multiple values separated by commas, for example:
"value1, value2, value3, value4"
I need to split this string using the comma delimiter and then add each value into a Value List property in Pega.
What is the best way to implement this?
Using a Data Transform?
Or any recommended approach to handle this in Pega?
If you have sample Java code or a best-practice solution, please share.
Thanks in advance!
@Eranda10274
You could make use of Apply-Parse-Delimited method in activity.
1) Create a Parse Delimited rule to parse the comma separated value and convert it to value list.
2) Call the same rule from activity by using Apply-Parse-Delimited method. Attached screen shot for reference.
Param.CCAddress = Comma Separated Values should be sent as an input parameter.
.AddressList = Return value will get stored in this value.
