Infinity 23 - JSON Log Appender
We are currently not able to monitor our Pega logs files correctly in ELK and need to create a separate logger in JSON format that be consumed correctly. I believe the steps below would need to be followed but would be grateful for a confirmation if anyone else done similar:
Pega uses Log4j2 with plain-text pattern layouts, though it does support natively logging through JSON layout.
- We need to locate the prlog4j2.jar and extract log4j2.xml
- Create a custom appender that uses JSON layout e.g.:
<Appender>
<File name="JsonFile" fileName="logs/pega-json.log" append="true">
<JsonLayout compact="true" eventEol="true" />
</File>
</Appender> - Attach it to the root logger e.g.:
<Loggers>
<Logger name="com.pega" level="Info" additivity="false">
<AppenderRef="JsonFile"/>
</Loggers>
</Loggers>
Note: Pega upgrades will overwrite the log4j2.
