Is it possible to install Pega Infinity on a personal laptop using the installation files available through my software access, or
I wanted to check if it's currently possible to install Pega Infinity on a personal laptop for individual learning and development purposes. I have access to the installation files through my software portal, but unable to run the install.bat file and I’ve also heard that Pega may have discontinued support for personal editions beyond version 8.7.
Could you please confirm whether personal installations are still supported for versions after 8.7? If so, are there any specific prerequisites or guidelines I should follow?
Looking forward to your guidance.
@Vinay_007
Pega Personal Edition was officially supported only up to version 8.7. Pega no longer provides installable personal editions for individual use or learning purposes.
Alternatively, you can use Pega academy’s cloud-based exercise environments for hands-on learning. Refer the the LSA Module and you should be able to file the Virtual MAchine file for the respective version which you can launch using a VMWare or Virtual Box.
You can also initiate a Community Edition which give you a free tail of 30-45 days for free.
