What are the upgrade steps from 24.1.1 to 24.2.2?
What are the upgrade steps from 24.1.1 to 24.2.2? Since this is a minor upgrade, can we just replace the container image or do we have to special updates to the Database using your update.sh script?
To upgrade from Pega 24.1.1 to 24.2.2, start by reviewing the release notes for any important changes. First, back up your system, including the database, to ensure you can restore if needed. Stop the Pega application and services, then replace the container image with the new one or apply the new version if using a traditional deployment. Even though it’s a minor upgrade, you’ll likely need to run the update.sh script to update the database schema. After the upgrade, run any post-upgrade scripts if required, then test the application to make sure everything works correctly. Finally, restart the application, monitor the logs for errors, and document the steps you took during the upgrade.
Support Doc
Support Doc
