CDH pzPersistResults is not true
How can i make this value to true?This filter filter our many actions
***Edited by Moderator Marissa to add Capability tags***
@haisuw65 To make the value of pzPersistResults
true, you need to locate the relevant property or field within your Pega application, typically in a data page or activity. If it's part of a filter or condition, check if there’s a when rule or decision table controlling its value. You can set this value to true
by modifying the corresponding logic or by explicitly setting it in a property set or in a flow action. Ensure that any rules or conditions relying on this filter are updated accordingly to reflect the change, so it no longer blocks actions as before.
@SairohithHi ,this filler value setting by pega. i think it shoule be changed by some nbad setting.
