Issue with Extract rule filter
HI All,
We are extracting pega tables to BIX using extract rule, in doing so I facing issue which setting up filter criteria .
Basically none of the properties we have created in class on which extract rule is created are coming in filter, on adding it manually, I'm getting error as "This is not a valid property, or this property cannot be used here". Although the property is optimized and exposed.
Hence, can anyone please help me on how I can use non OOTB, exposed properties in extract rule filter.
Please refer the attachment
Thanks in advance.
Hi @im-ankit,
Set a value for the Access Group property. The error may be due to it being blank.
Mohd Qizer
