Data at rest Encryption in Pega Cloud Sales Automation
I need to know if we allow BYOK approach for pega cloud Sales Automation application how we support for Digital Channel.
@Gaurav25 ⚠ This is a GenAI-powered tool. All generated answers require validation against the provided references.
Yes, Pega Cloud does support BYOK encryption for applications, including Sales Automation. For Pega Cloud deployments, Pega manages the infrastructure-level encryption keys for your environment automatically, including key rotation on a periodic basis through a FIPS 140-2 compliant Key Management Service (KMS).
All client data stored in volumes, databases, and object storage buckets in a Pega Cloud environment are encrypted with 256-bit encryption by default. This applies to Sales Automation applications as well.
For Digital Channels specifically, BYOK encryption is supported from version 8.8+. Organizations with stricter data and privacy policies can implement BYOK encryption for the Web Messaging and Mobile Messaging SDK connections in the Digital Messaging channel.
The BYOK encryption method for Digital Messaging provides end-to-end encryption that prevents Digital Messaging Service from accessing the chat message contents transmitted between a customer's session and your Pega application. This works through a system of key pairs:
When implementing BYOK for Digital Messaging with Sales Automation, you would need to:
It's worth noting that in earlier versions (such as 8.8.0), BYOK encryption did not apply to file attachments, transcript downloads, or conversation history. However, BYOK encryption for these features is supported starting from Pega Platform application version 24.1.3, 24.2.1, and later.
References:
@MireilleDallaire please comment if required.
