  Ford Motor Company
Last activity: 12 Mar 2025 10:13 EDT
Gen AI Functionality
Currently all Gen AI capabilities provided are only for Constellation based UI (except Knowledge Buddy and Blue Print). Is there any plan to add these capabilities to Cosmos UI? Most of the applications in the wild are on Cosmos UI and will take some more time to be on Constellation UI. If you want fast adoption of Constellation UI, then there should be a OOTB converter. I understand making Gen AI capabilities available to UIKit doesn't make sense. When a new feature is introduced, it should have some backward compatibility?
Thanks.
  Reply
Updated: 12 Mar 2025 10:13 EDT
@Mohan Kumar A as detailed by Aditi, this functionality is not available currently.
If you wish to track the Enhancement Request work mentioned previously, you can quote EPIC-100217 (Support GenAI Coach/Agents on traditional applications) to your Account Executive if you need more information.
Below a GenAI-tool answer for possible technical reasons behind these architectural choices.
AI-powered tools may produce incomplete or inaccurate answers. For important decisions, do not rely solely on the tool's responses. Always validate generated answers against the provided references.
Why Connect GenAI Requires Constellation
Connect GenAI was designed specifically to leverage the unique capabilities and architecture that Constellation provides. Constellation features a center-out approach that focuses on business outcomes and customer journeys, allowing for a more seamless integration of AI functionalities. This modern architecture supports the latest open-source technologies and UI solutions needed for GenAI to function optimally.
The Constellation architecture provides several technical advantages that make it better suited for GenAI integration:
- It employs a modular design that adapts to various screen sizes, ensuring high-quality user experiences across devices
- It features built-in accessibility compliance with front-end best practices
- It offers a more configurable UI framework that can better accommodate the dynamic nature of AI-generated content
Why There Is No Backward Compatibility
The lack of backward compatibility stems from fundamental architectural differences between Constellation and Theme Cosmos. Theme Cosmos follows a traditional UI approach with its own set of components, templates, and interaction patterns that weren't designed with GenAI capabilities in mind.
Making Connect GenAI backward compatible would require:
- Significant re-engineering of how GenAI interfaces with the UI layer
- Creating duplicate functionality across two different architecture paradigms
- Maintaining compatibility between systems with fundamentally different design principles
These challenges would likely introduce performance issues, user experience inconsistencies, and ongoing maintenance complexities.
Why GenAI Can't Be Shipped with Theme Cosmos
While Connect GenAI can be connected via a connect rule, shipping it with Theme Cosmos presents several technical challenges:
- The underlying technologies that power GenAI rely on Constellation's architecture for optimal performance
- Theme Cosmos lacks certain UI components and interaction patterns needed for effective GenAI integration
- Bundling GenAI with Theme Cosmos would require maintaining two separate codebases for the same functionality, which would increase complexity and potential for bugs
Additionally, Pega's development roadmap appears to be prioritizing Constellation as the future UI framework, with new features like GenAI being built to take advantage of its modern architecture.
References:
- Overview of Pega AI in Pega Cloud
- Creating a Connect Generative AI Rule
- Why Constellation?
- Integrating with Pega GenAI
As of Infinity 24, Only Pega GenAI Coach is not available in traditional UI (Theme Cosmos).
Rest of the features can be enabled for traditional UI. You can find more details in this article - docs.pega.com/bundle/platform/page/platform/data-integration/integrating-gen-ai.html
  Ford Motor Company
@Aditi Mehta
Thanks for the details. I have used Connect GenAI for building DIY GenAI capabilities. But my ask is why there is no backward compatability? Any reason why it has to be on Constellation?
If GenAI can be connected via a connect rule, why not ship it with the product to support Theme Cosmos?
We are working on providing this capability for non-constellation apps as well in Infinity 25 release.
If possible, can you share the use case you are trying to implement.
  Ford Motor Company
@Aditi Mehta
Our applications are in Theme Cosmos and some of them are still moving to Theme Cosmos. So, it would be better if we have these GenAI capabilities available for the applications as well.
References:
