Upgrading to Pega 24.2
When I run the update.sh script I receive the following and the process stops.
I can't determine what the problem is.
crmpoc:/pega_software/pega24.2/scripts: ./upgrade.sh
INFO ResumeKt - Detected resume.properties, but automatic.resume flag in setupDatabase.properties is set to false.
INFO ResumeKt - Starting over upgrade
INFO ResumeKt - Performing upgrade...
INFO AntScriptWrapper -
INFO AntScriptWrapper - Initialization:
INFO AntScriptWrapper - [echo] Performing Upgrade
INFO AntScriptWrapper - [delete] Deleting: /pega_software/pega24.2/scripts/resume.properties
INFO AntScriptWrapper - [delete] Deleting directory /pega_software/pega24.2/scripts/taskRuntimes
INFO AntScriptWrapper - [mkdir] Created dir: /pega_software/pega24.2/scripts/taskRuntimes
INFO AntScriptWrapper - [delete] Deleting: /pega_software/pega24.2/scripts/logs/Warnings.log
INFO AntScriptWrapper - [pega:propertyparser] Reading Properties from: /pega_software/pega24.2/scripts/setupDatabase.properties
INFO AntScriptWrapper - [pega:propertyparser] pega.jdbc.driver.class=oracle.jdbc.OracleDriver
INFO AntScriptWrapper - [pega:propertyparser] update.existing.applications=false
INFO AntScriptWrapper - [pega:propertyparser] bypass.udf.generation=true
INFO AntScriptWrapper - [pega:propertyparser] pega.jdbc.password=*****
INFO AntScriptWrapper - [pega:propertyparser] update.applications.schema=false
INFO AntScriptWrapper - [pega:propertyparser] automatic.resume=false
INFO AntScriptWrapper - [pega:propertyparser] pega.jdbc.driver.jar=/oracle_software/19.17.0/jdbc/lib/ojdbc8.jar
INFO AntScriptWrapper - [pega:propertyparser] rules.schema.name=rules_admin
INFO AntScriptWrapper - [pega:propertyparser] run.ruleset.cleanup=true
INFO AntScriptWrapper - [pega:propertyparser] pega.jdbc.url=jdbc:oracle:thin:@//hapdevel2.hap.org:1521/crmpoc.hap.org
INFO AntScriptWrapper - [pega:propertyparser] pega.database.type=oracledate
INFO AntScriptWrapper - [pega:propertyparser] user.temp.dir=/pega_software/pega24.2/temp
INFO AntScriptWrapper - [pega:propertyparser] production.level=2
INFO AntScriptWrapper - [pega:propertyparser] customerdata.schema.name=
INFO AntScriptWrapper - [pega:propertyparser] pega.jdbc.username=pega_admin
INFO AntScriptWrapper - [pega:propertyparser] bypass.pega.schema=
INFO AntScriptWrapper - [pega:propertyparser] pega.admin.password=*****
INFO AntScriptWrapper - [pega:propertyparser] data.schema.name=crm_admin
INFO AntScriptWrapper - [pega:propertyparser] system.name=pega
INFO AntScriptWrapper - [echo] Using logging configuration from: /pega_software/pega24.2/scripts/config/deploylogging.properties
INFO AntScriptWrapper - [echo] *** JVM Arguments -Xmx4g -Djava.security.egd=file:///dev/urandom -XX:+HeapDumpOnOutOfMemoryError -Djava.util.logging.config.file='/pega_software/pega24.2/scripts/config/deploylogging.properties' ***
INFO AntScriptWrapper - [propertyfile] Creating new property file: /pega_software/pega24.2/scripts/resume.properties
INFO AntScriptWrapper - [propertyfile] Updating property file: /pega_software/pega24.2/scripts/resume.properties
Found 27155420KB of free space on '/pega_software/pega24.2/temp'
INFO AntScriptWrapper - [echo] Driver Path: /oracle_software/19.17.0/jdbc/lib/ojdbc8.jar
INFO AntScriptWrapper - [pega:getbuildcodesetversion] Found runtime codeset version FS_ONLY
INFO AntScriptWrapper - [pega:getbuildcodesetversion] Found manifest codeset version 08-24-51
INFO AntScriptWrapper - [mkdir] Created dir: /pega_software/pega24.2/temp/PegaInstallTemp-15-January-2025-18.59.27/load
INFO AntScriptWrapper - [mkdir] Created dir: /pega_software/pega24.2/temp/PegaInstallTemp-15-January-2025-18.59.27/pr_temp
INFO AntScriptWrapper - [touch] Creating /pega_software/pega24.2/scripts/logs/Warnings.log
INFO AntScriptWrapper - [echo] Using /pega_software/pega24.2/temp/PegaInstallTemp-15-January-2025-18.59.27 for install scratch space...
INFO AntScriptWrapper - [copy] Copying 1 file to /pega_software/pega24.2/temp/PegaInstallTemp-15-January-2025-18.59.27/load
Exception in thread "main" /pega_software/pega24.2/scripts/setupDatabase.xml:796: java.lang.NullPointerException
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:109)
at org.apache.tools.ant.Task.perform(Task.java:350)
at org.apache.tools.ant.Target.execute(Target.java:449)
at org.apache.tools.ant.Target.performTasks(Target.java:470)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1401)
at org.apache.tools.ant.Project.executeTarget(Project.java:1374)
at com.pega.deploy.AntScriptWrapper.invokeAntTarget(AntScriptWrapper.kt:94)
at com.pega.deploy.SetupDatabase.initialization(SetupDatabase.kt:166)
at com.pega.deploy.UpgradeKt.rulesUpgrade(Upgrade.kt:101)
at com.pega.deploy.UpgradeKt.main(Upgrade.kt:41)
at com.pega.deploy.UpgradeKt.main(Upgrade.kt)
Caused by: java.lang.NullPointerException
at java.security.SecureRandom.nextBytes(SecureRandom.java:475)
at java.security.SecureRandom.next(SecureRandom.java:498)
at java.util.Random.nextLong(Random.java:435)
at java.nio.file.TempFileHelper.generatePath(TempFileHelper.java:69)
at java.nio.file.TempFileHelper.create(TempFileHelper.java:138)
at java.nio.file.TempFileHelper.createTempFile(TempFileHelper.java:172)
at java.nio.file.Files.createTempFile(Files.java:863)
at org.apache.tools.ant.util.FileUtils.createTempFile(FileUtils.java:1035)
at org.apache.tools.ant.taskdefs.Replace.processFile(Replace.java:652)
at org.apache.tools.ant.taskdefs.Replace.execute(Replace.java:533)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:299)
at sun.reflect.GeneratedMethodAccessor6.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55)
at java.lang.reflect.Method.invoke(Method.java:508)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:99)
... 10 more
Java Process returned a non 0 value
@JohnP695
I think I found the problem. It appears that Java 8 is no longer supported only Java 17. I'm having our Sys Admin install Java 17.
