About Pega's Filter Management feature
When the Filter Management settings are applied, what kind of screen will be displayed to the user?
If Filter Management fails, the end user will typically encounter an error screen or message indicating that the filter management operation could not be completed. Here’s what you can expect:
The user will see an error message that explains the failure of the filter management operation.
The message may include specific details about what went wrong, such as configuration issues or permission problems.
@Dharanidharan Hi, Thank you for the reply. What I want to know is that, If a source which is blocked by Filter Management setting attempts to access to the system, what screen will be displayed to the source? For example, will it result in a 404 error? Best, Fan
Support Doc
