Wipro Ltd
Wipro Ltd
Wipro Ltd
Posted: Nov 11, 2024
Last activity: Jan 9, 2025
Last activity: 9 Jan 2025 11:28 EST
Query String Param
pxQuerystring Param is not getting refreshed when the current requestor session param is changed in endpoint url ?
***Edited by Moderator Marissa to change type from General to Product, added Product details and Capability tags***
@HemavathiV
The pxQueryString parameter does not get refreshed because Pega CM does not allow 'non Pega CM' parameters in the query string to survive form posts. When the login activity runs and the login screen is displayed the parameters from the URL are dropped. To retain these parameters you would need to map them to the clipboard using the pyQueryString parameter and then add them to the login screen. This way the parameters can be accessed when the user submits their credentials.
How to read Extra Parameter during Log In
If you need further help please log a support incident via the MSP and provide the INC id here.
