Error "Cannot add new node. Make sure all listed nodes are available or reattach the volume from one of these nodes to this node"
Any suggestion on this issue.....
2024-09-24 14:58:49,283 [StreamServer.Default] [ STANDARD] [ ] [ ] (rvice.operation.StartOperation) ERROR - Cannot
start service [StreamServer.Default]. Will retry in 180 seconds. Remaining attempts: 2
com.pega.dsm.dnode.api.StreamServiceException: Cannot add new node. Make sure all listed nodes are available or reattach the volume from one of these nodes t
o this node.
[Node=pegabatchserver101, broker=1005]
at com.pega.dsm.dnode.api.server.StreamServerService$StreamServiceStartOperation$2.emit(StreamServerService.java:675) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:353) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:55) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.await(DataObservableImpl.java:117) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.await(DataObservableImpl.java:106) ~[d-node.jar:?]
o this node.
at com.pega.dsm.dnode.api.prpc.service.operation.StartOperation$1.execute(StartOperation.java:167) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.OperationWithLock$LockingOperation.couldAcquireLock(OperationWithLock.java:190) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.OperationWithLock$LockingOperation.performLockOperation(OperationWithLock.java:157) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.OperationWithLock$LockingOperation.access$200(OperationWithLock.java:102) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.OperationWithLock.doWithLock(OperationWithLock.java:99) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.OperationWithLock.doWithLock(OperationWithLock.java:95) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeWithLockInternal(ServiceHelper.java:273) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeWithLock(ServiceHelper.java:221) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.prpc.service.operation.StartOperation.doActualServerStart(StartOperation.java:164) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.prpc.service.operation.StartOperation.performStartupWithRetries(StartOperation.java:137) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.prpc.service.operation.StartOperation.initializeServerMode(StartOperation.java:117) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.prpc.service.operation.StartOperation.lambda$bootstrap$0(StartOperation.java:85) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceDefinition.startService(ServiceDefinition.java:81) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceDefinition.start(ServiceDefinition.java:66) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.prpc.service.ServiceManager$4.run(ServiceManager.java:429) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:77) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContextInternal(ServiceHelper.java:305) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContext(ServiceHelper.java:150) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.prpc.service.ServiceManager.startServiceDefinition(ServiceManager.java:426) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.prpc.service.ServiceManager.lambda$bootstrap$3(ServiceManager.java:388) ~[d-node.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_351]
at com.google.common.util.concurrent.TrustedListenableFutureTask$TrustedFutureInterruptibleTask.runInterruptibly(TrustedListenableFutureTask.java:125
) ~[guava-25.1-jre.jar:?]
at com.google.common.util.concurrent.InterruptibleTask.run(InterruptibleTask.java:57) ~[guava-25.1-jre.jar:?]
at com.google.common.util.concurrent.TrustedListenableFutureTask.run(TrustedListenableFutureTask.java:78) ~[guava-25.1-jre.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:1.8.0_351]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:1.8.0_351]
at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:69) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:66) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.PrpcThreadFactory$PrpcThread.run(PrpcThreadFactory.java:164) ~[d-node.jar:?]
2024-09-24 15:07:52,892 [StreamServer.Default] [ STANDARD] [ ] [ ] (prpc.service.ServiceDefinition) ERROR - Failed
to start service: [StreamServer.Default]
o this node.
Application is not accessible due to this issue
***Edited by Moderator Marije to change Content Type from Discussion to Question; added capability tags***
