Deloitte Touche Tohmatsu India LLP
Last activity: 30 Sep 2024 2:46 EDT
Unable to create property accountID
Hi All
We have a scenario as below:
1. In Pega CDH we have json ingestion file with field as accountID. 2. We have file listener reading the file in repository path and we are running the data flow. 3. In Data flow the source is data set having the repository path of json file. 4. Issue is happening while parsing and saving accountID field as there is an existing AccountID property in baseclass. 5. Hence getting below error while creating accountID pyPropertyName— A case mismatch has been found for this property: 'accountID' doesn't match 'AccountID' Error— Definition required to conform to PegaCDH-Data-FS-Account.AccountID instance created 2023 6. FYI, data team proving the json file cannot change spelling or case in the file. Has to be handled at pega end.
A solution or expected suggestions to this would be greatly appreciated.
