Read Only Access on Pega container
Hello!
Can the Pega container run with read only root file system access in k8s? In securityContext can we set readOnlyRootFilesystem in the helm chart in combination with the mounts needed for the mutable data?
Hello!
@d.mcphail The Pega Platform Docker image should be run as a non root user using a custom security context. While the context provided does not explicitly mention setting readOnlyRootFilesystem it is important to ensure that your environment meets the necessary requirements for running the Pega Platform. You can configure the security context in your Helm chart but you should verify that all necessary mounts for mutable data are correctly set up to avoid permission issues.
Support Doc
