Tata Consultancy Services
Posted: Sep 9, 2024
Last activity: Sep 9, 2024
Last activity: 9 Sep 2024 11:33 EDT
Unable to upload the Pega Blueprint
Hi Team -
We are unable to upload the attached Blueprint (in pdf format as .Blueprint extension is not allowed to upload here). We are getting the below error as attached. Kindly help to resolve the issue.
Ashojk
@ASHOKKUMAR can you confirm that you checked the documentation:
Creating a new application from a Blueprint
The error message indicates that the PegaCLMFSCIB Application must be present on your system and configured for use in the New Application Wizard. This is similar to the issue with the PFSAPER application which is the Payment Exception Recovery application. You would need to install the relevant application in this case Pega Client Lifecycle Management for Financial Services to resolve this issue. Ensure that the application is properly installed and configured on your system.
The import of this Blueprint requires the PFSAPER Application to exist on this system and for it to be configured for use in the New Application Wizard.
Importing the application
