Last activity: 12 Sep 2024 12:31 EDT
SAML Authentication Error
We are configuring SAML for authenticating into our application with Okta as IdP. More details on what we have done in Pega 7.1 -
a. SAML Auth service used, so no changes in prweb.xml file.
b. SAMLAuthIDPCertStore which was created automatically has been used at IdP setting and SP setting of auth service.
c. Attribute NameID has been mapped to pyUserIdentifier
d. Auth service is built on our version of Unauthenticated ruleset (which has been saved as from original Unauthenticated)
1* While accessing application through IdP , are are getting "Unable to process the SAML WebSSO request : 1"
The log shows - Error while executing the Assertion Consumer Service activity : 1
pyAssertionConsumerServiceActivity - In this activity Java method to Parse the response message into SAMLResponse and RelayState is having exception.
@VinayakB16597079
The error message "Unable to process the SAML WebSSO request : 1" typically indicates an issue with the SAML response from the IdP. This could be due to a variety of reasons, such as an issue with the SAML Assertion, the SAML Response, or the RelayState. It could also be due to an issue with the parsing of the SAML response in the Assertion Consumer Service activity.
You may want to check the following:
If the issue persists, it might be a good idea to reach out to Pega Support for further assistance.
Unable to process the SAML WebSSO request : Unable to process SAML2 Authe
SAML 2.0 SSO Implementation in 7.4
@VinayakB16597079
OOTB pySAMLWebSSOTimeoutActivity and pySAMLWebSSOAuthenticationActivity are
setting SSO usign ADFS
SSO Authentication Error
