How to Set SLA Access Group
I need to set runtime specific access group when SLA running, anyone know how to do this?
Hi @Intandhp,
Create a activity or data transform, then Add a step with the method Property-Set and then Set the property pyAccessGroup to the desired access group name and then save the activity and add it to your SLA.
Prasad.
@Intandhp Basically SLA works on an agent and that agent has specific access group . If you will change the Access group of that agent you can update the Access group for that SLA basically .
Hi @Intandhp,
Prasad.
