Blue Rose Technologies LLC
DE
Last activity: 10 Sep 2025 6:35 EDT
Custom DX components not appearing in AppStudio
Using DX Component Builder and Infinity Server '24.
A custom field was successfully created and published via command line. But, I could not find the field via App Studio. Trying to add the new field sample application.
Ran the following:
- npm run create
- npm run buildComponent
- npm run authenticate
- npm run publish
When I ran `npm run list` and selected server, I can see custom component being listed.
Operator id has `Allow rule check out` checked.
Reply
Updated: 24 Jun 2024 8:34 EDT
DE
@SureshC5289 Thank you all for checking this. the issue is now resolved. As it is Lab instance some of the services are not responding, raised a ticket for the support and now able to see the components.
I have seen this issue. Can you please open the application definition rule in Dev Studio and click on 'Save'.
DE
@RameshSangili thank you for the responding, I have resaved the application and rearranged the rulesets and logged off and in again. But still not able to see the components.
NAB
@SureshC5289 Saving the Ruleset of application might be helpful in this case. Once happened with me i logged out and saved the application. Have a try in case it works. Thanks Somil
DE
@Somil Shukla thank you for the responding, I have resaved the ruleset and logged off and in again. But still not able to see the components.
A couple of things you can check.
Can you see the component if you review instances of Rule-UI-Component in Dev Studio, and is it in the ruleset that you are expecting (The one you entered when selecting npm run publish?
What is the default access group of the user you authenticated with when you ran npm run authenticate, and did this access group have access to the ruleset that you entered to publish the component to? I have seen components end up in a different ruleset if the user is using a default access group that does not have one entered.
When you created the component did you make is available to all applications or just a named application, and if so does this match the application that you are trying to use it in?
DE
@Marc Alderman Thank you Marc.
I am able to see the component in the given ruleset version in Dev studio.
When I authenticated, I used a user that has the access to the ruleset given in the publish command.
Also made this component to all the applications.
Was thinking if this has to do anything with the constellation service or cache. How ever I am able to see few other components that are published like 3 weeks back. but this issue was introduced from the last two weeks.
I am working on Pega Infinity Lab instance.
ING
@Marc Alderman I've a question regarding creating a custom component with CS FW using Constellation
Do you have any steps to implement , Is it possible to create a custom custom??
i know without this FW this is allowed, need to confirm on CS with constellation
Acel Solutions Pvt Ltd
Hi suresh
What type of custom field you have created the same of type should be created in AppStudio and inside that field you will get option like "Display as" in that you can see your custom fields
for example:-
you created a custom field of type Text Input
now in App Studio create a filed of type text Input after that click on that field gear icon in that you can you custom fields.
DE
@FirdozK02 have created the same fields in Builder and in Appstudio. but it was not appearing.
Cisco
@SureshC5289 Hi Suresh, step 1: I downloaded the "ConstellationUIGallery_2_0_4_COMPONENTS_ONLY.zip" from "https://github.com/pegasystems/constellation-ui-gallery/releases/tag/2.0.4" and imported successfully in my pega 24.1.2. step 2: All the components available in "Rule-UI-Component" class. BUT NOT IN APP STUDIO I'm not getting this option "Display as" in app studio. Anything I'm missing? Please help me to resolve this issue. Thank you!
DE
Macquarie Group
PH
@SureshC5289 - Hi Good Day.Could you share your fix for this? I also encountered the same issue. Thanks a lot
Hi @SureshC5289
Do you mind sharing the ticket you raised with support so we can connect this post with it?
Thank you!
ING
@umamaheswar.bk please post your question as a New Question as this thread was resolved a long time ago.
You can always use the @ tagging mechanism to notify followers of previous posts.
Macquarie Group
PH
@SureshC5289 Hello, hopefully this attachement can help in issue of displaying dx component in app studio.
