ai4process
Last activity: 24 Jun 2024 8:51 EDT
Setting component to transparent in theme.json file
I'm trying to set this header to be a bit transparent.
This is the JSON file I want to use to make the header transparent.
"base": {
"palette": {
"app-background": "#daf5f3"
"transparency":{
"transparent-1": 0.3
"components": {
"app-shell": {
"nav": {
"background-color": "#7c3f00"
"header":{"transparent":"0.3"}
"card":{"border-radius":"92rem"}
The error I get states header has no property transparent.
This record has 1 error(s) in 1 place(s) .
JSON.components['app-shell'].header should NOT have additional properties - transparency
Below are some of the options I have tried, they all give me the same error, that header does not have the property i'm trying to use.
"header":{"transparency":"0.3"}
"header":{"transparent-1"}
"header":{"base.transparency.transparent-1":0.3}
"header":{"Transparency":"base.transparency.transparent-1"}
"header":{"transparency":"base.transparency.transparent-1"}
The documentation doesn't really show a use case for transparency for a component.
"base": {
"palette": {
"transparency":{
"components": {
"app-shell": {
"nav": {
What should i do to make the header transparent with my theme.JSON file? What more information should I provide to help answer the question?
