Eclatprime Digital Private limited
Last activity: 2 Apr 2024 2:06 EDT
Pega RPA robot inspector
How to get GETROWCOLUMN method for lookup table in PDF automation challenge.
there is no any GETROWCOLUMN method.
Reply
Updated: 2 Apr 2024 2:06 EDT
@ThomasSasnettThe methods you are looking for are actually provided in an extension. That extension is included in the sample solution attached to the exercise. They are not present in the lookup table (in 19.1 anyway) out of the box.
@VANAMAS16755149Would you please provide a little more detail? I am not entirely familiar with the challenge you are referring to offhand. Do you have a link to it and a specific part you are having questions about? Any specifics you can provide that would show me what you are seeing would be helpful.
@ThomasSasnett kindly find the below link
https://academy.pega.com/challenge/accessing-pdf-data-automations/v1
@VANAMAS16755149 What version of Pega Robotics Studio are you using for this exercise?
Pega Robot Studio Version 14.0.25420.1 D14REL Microsoft .NET Framework Version 4.8.09037
Installed Version: Express
Pega Robot Studio Proprietary information hidden Copyright © 2001-2019 All rights reserved Pegasystems Inc.
@VANAMAS16755149 Hi,
Portions utilize Log4Net: Apache log4net Copyright © 2004-2017 The Apache Software Foundation Portions utilize Newtonsoft Json.net Copyright © 2007 James Newton-King Portions utilize CefSharp Copyright © 2010-2014 The CefSharp Authors Portions utilize Command Line Parser Library Copyright © 2005 - 2015 Giacomo Stelluti Scala & Contributors Portions utilize PdfiumViewer Copyright © 2012-2015 Pieter van Ginkel Portions utilize Html Agility Pack Copyright © ZZZ Projects Inc. 2014 - 2017. All rights reserved. Portions utilize QPDF Copyright © 2005-2019 Jay Berkenbilt Portions utilize PDFSharp Copyright © 2005-2018 empira Software GmbH, Troisdorf (Germany) Portions utilize SharpZipLib Copyright © 2000-2018 SharpZipLib Contributors Portions utilize gson Copyright © 2012 Google Inc. Portions utilize TinyIoc Copyright © Steven Robbins. Portions utilize almond Copyright © 2011, The Dojo Foundation Portions utilize async.js Copyright © 2010 Elijah Grey Portions utilize bootstrap Copyright © 2011-2019 Twitter, Inc. Portions utilize Durandal Copyright © 2012 Blue Spire Consulting, Inc. Portions utilize jquery Copyright © 2005, 2012 jQuery Foundation, Inc. and other contributors Portions utilize jwerty Copyright © 2013, Keith Cirkel Portions utilize knockout Copyright © Steven Sanderson - http://knockoutjs.com/ Portions utilize moment.js Copyright © JS Foundation and other contributors Portions utilize RequireJS Copyright © 2010-2012, The Dojo Foundation Portions utilize RequireJS text 2.0.3 Copyright © 2010-2012, The Dojo Foundation Portions utilize EasyHook Copyright © 2009 Christoph Husse & Copyright © 2012 Justin Stenning Portions utilize MailKit Copyright © 2013-2019 Xamarin Inc. Portions utilize MimeKit Copyright © 2012-2018 Xamarin Inc.
More information can be found in the THIRDPARTYLICENSES.TXT file delivered with the software.
@VANAMAS16755149If you select Help-->About in Studio, you should see a dialog named "About Pega Robot Studio". In the "Install Products" section, you should see a version like 19.1.120. That would be the version of Pega Robotics.
@ThomasSasnett Hi,
@VANAMAS16755149 I have a question. Did you access this particular exercise through a Mission on a course. If so, what mission are you enrolled in?
@VANAMAS16755149I am trying to determine why that method is not available in 19.1. It clearly was at some point based on the screenshots, however I do not see it in the later versions. It is present in 22.1. If you can use that version, then you can more easily replicate that training. You can substitute the GetRecord method in place of it to complete the material in 19.1 though.
